A small update to the dovetail jig. Since you can easily remove the vertical braces, I figured that you could just clamp thicker things directly to the base plate with clamps - same system as used in the Festool worktable (you can use the same clamps). If you are normally routing items that are not so wide, you can also have one of the vertical braces fixed tightly as a fence to ensure that the work items are perpendicular to the bed.
	26-09-2015 #2
If it was me I'd have a combination of 3 things.
#1 Clamps as shown.
#2 Matrix Grid of Threaded holes for clamping Odd shapes with mill type clamps.
#3 several larger holes for Festo type clamps for deep items.
Oh and I forgot to say I'd get lift those bottom rails up about 75-100mm to create short stumpy feet for levleing and lose 2 of the diagonals wich are not required. Less welding, less chance of heat distortion.
	27-09-2015 #3
Yes, good idea JAZZ. Some holes with T-nuts would increase the possibilities for fastening things. I actually thought that I extended the legs under the lower frame, but apparently I didn't. Also eliminated the lower beam I inserted for mounting the dovetail jig. I removed 2 of the diagonals since they are not required.
	27-09-2015 #4
Yes, I agee on the costs.
Many of my choices would be different if I did not do things for commercial uses.
Haas has the lowest costs in the industry.
A servo amplifier (ie driver) (just electronics) costs 500.
The same from yakawa or siemens costs 2500.
The ones I use cost about 350 for the same size, circa 1kW.
Like I said, the MPG wheel is only 30 or 40.
	27-09-2015 #5
If money was no object I would go for the servo motors.
Do you have a link to a good MPG for 30 or 40€? The ones I found were approx. twice that.
	27-09-2015 #6
Depends if your just talking about the MPG pulse generator like hannu probably is or what people often mistakenly call MPG but should call Pendant with all the other controls on it.?
Here's 2 of the MPG pulse generators. 25 pulses per Rev and 100 P/R. 100 is most commonly used I think.!
http://www.aliexpress.com/store/prod...540014466.html
http://www.aliexpress.com/store/prod...506063450.html
BUILD LOG: Comments sought on new build: A CNC Router for RC Gliders and Planes
By njhussey in forum DIY Router Build LogsReplies: 817Last Post: 13-04-2020, 05:03 PM -
Aluminum router build - Could use some input
By Tumblebeer in forum Gantry/Router Machines & BuildingReplies: 17Last Post: 01-09-2014, 09:48 PM -
Help appreciated
By joncdrl in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 17-09-2012, 08:34 PM
